murando531
Hey all!
It's been almost three months since getting the new Bravos XL replacement, and man do I love this washer. Has had a few weird incidents with noises but what machine doesn't? It has been golden compared to the previous one I had so I am beyond happy.
That said, since this one seems to be built properly and is performing like a champ, I'd like to keep it that way for as long as humanly/machinely possible. The biggest issues I've heard when it comes to the Cabrio-Oasis washer family are bearing problems and issues with the shaft becoming corroded to the point where the tub cannot freely float up and down. I'm making sure to run the Clean Washer cycle everytime the light comes on, but honestly the machine keeps itself sparkling clean on its own, possibly because I don't overkill on the detergent use and I use microscopic amounts of fabric softener if I even use it at all. The clean cycle uses a pretty violent spin with water rushing around underneath the tub, so I'm hoping that also keeps the driveshaft and the seal clean of corrosives.
So, if anyone has advice on anything I can do to make sure it's always in top shape, please let me know! Things such as: does the tub need to be taken out every 6 or so months to oil the driveshaft, and what kind of lubricant should be used? I'd be eternally grateful! I've found something that is "new" and modern that I actually like, so I want to be good to it.
