Oh MAN...
roto204
Feb 5, 2010
2,779
Tucson, AZ
Hey everyone,
I don't know how I did it, but I lost the T-bearing that rides atop my '61 Kenmore transmission. I ended up rebuilding the transmission the other evening, and managed to apparently keep track of everything but that.
If you saw what I had to work with insofar as a workspace, this might seem less ridiculous than it sounds...
Does anyone have the part # for this or have another one lying around? No doubt it'll turn up if I find another, but since I can't do much without it...
Thank you SO MUCH for your help...
--Nate the inept
Actually...
...does anyone have a pic of the old-style T bearing from this era? Is it a simple brass (or whatever gold-ish metal) sleeve that has a flat edge?
I'm thinking I misidentified it and put it in a different parts bag, but I need to jog my memory and recall what it looks like...
I think I have one!!
Hey Nate. I believe that I may have that t-bearing in my parts stash. It came off a '68 transmission. As I recollect, it is made of brown plastic instead of the off-white plastic that the newer BD machines used, and it has a bronze top on it. I'll look and see if I can find it and if so, will let you know.
Dennis
It is simply a brass Tee bearing that rides atop the collar. The collar has a set screw in it.
If you can't find it you can use the plastic one piece bearing replacement that has a locating steel ball instead of the set screw. Wouldn't be original but it will work.
MrMaytag, That Tee bearing won't work witn the old style trans shaft. The one you have uses a groove with a 2 piece clip to stop it. The old trans shaft doesn't have the groove.
And NO NATE, you are NOT inept!! If ya don't change your thought, I"m gonna come out there and make you stand in a small room with Ross' new 59 Kenmore with the out of balance buzzer ringing (pretty annoying) and keep it buzzing for a few hours!!! HA
Anyway, hang in there. Your search will be resolved one way or the other. Bob
Yay, I'm a moron!
LOL
Okay, y'all ready for this?
I reinserted it in the transmission because I was a dumb@#$, and apparently I hallucinated or some such between disassembly and reassembly.
I tore it apart, fished it out, and put it back where it belongs.
Thank you for the description--that jogged my memory and allowed me to remember what happened.
Now, assuming that things are copasetic, it should be ready for reassembly once I get the cabinet repainted...
*sigh*
Thank you so much for the moral support--I've reassembled old machines from bits and pieces from my grandfather's junkyard, but never had to tear down a tranny before :-|
LOL Bob--my machine has that off-balance buzzer too. What a treat! (*sound of grinding teeth*)
