OLD EverHot roaster- any info?
dustin92
Jun 21, 2010
1,215
Jackson, MI
I just got an Everhot roaster, I am starting to clean it up and am planning to give it to my Mom for Christmas because she wants a roaster. I got this one because I didnt want to get a new, made in china piece of junk, and because this one is in EXCELLENT condition. I paid $10 for it and it came with the racks and the instruction book/ cookbook. I am guessing it is from the 50's? But if anybody knows for sure, please tell! It has a cloth covered cord and it looks like it is in good shape, but is somewhat stiff, can anybody tell me if it will be safe to use or not, and if not, where I can get another one. There is a couple of spots where the white paint has flaked off; what would be a suitable touch up paint? Also, what can I use to remove some small specks of burned on grease from the inside of the lid? I have tried oven cleaner and then comet, and neither of them would shift it. Pics will follow!
full view- the knob on the left contols the temp, the wheel in the middle is a cooking guide, and the knob on the right opens and closes the lid.
Great old roaster
Dustin - Congrats on your new (old) roaster! I'm sure your mom will love it! I have a model close to yours, and it always has done a great job roasting, baking and slow cooking all kinds of food. How great that you have the owner's manual, too!
Since the lid is aluminum, you may want to try an SOS/Brillo pad - that seems to usually do the job in getting that caked on grease off. You may want to use some appliance touch-up paint on the spots where the original paint has flaked off. You can find it at many hardware stores - it comes in a small bottle. They generally always have white. While you're there, you could probably find a new cord, but if your cloth covered one is not frayed and the socket end (that fits into the roaster) is not rusted or damaged, there shouldn't be any problem using it.
Everhot was made by the Swartzbaugh Electric Corp. in Toledo, Ohio and they made them in various sizes, including a smaller round model they called the "Roaster-ette." Chances are yours was made sometime between 1948 and 1954. They were a lower-priced alternative to the Nesco and Westinghouse roasters which dominated the market and were sold mostly in the midwest states.
I hope you and your mom enjoy years of good cooking from your roaster!
I had a chance to plug it in today, and it seems to work fine, but the indicator light behind the cooking guide flickered constantly(dimmed and then brightened) but didnt go out. I am wondering if this is anything to worry about, or just needs to have the bulb replaced. It did go on and off as the roaster cycled though. Also, the plug that plugs into the roaster got pretty hot, the cord and wall end stayed cool though. Is this normal?, and if not, what can be done to fix it.
Flicker fix
It depends on the type of bulb the indicator light uses. My mom's '49 Westinghouse range had a similar issue with the indicator light. It was a tiny bulb with a threaded base. There was a loose connection of some sort but when looking at the assembly, it appeared to be more trouble than it was worth to fix. It never caused a problem and it behaved that way for decades. Who knows? You may have a bulb that just needs tightening into place.
If the plug got hot, you should consider replacing it. Usually a hot plug is an indicator that electricity is being wasted as a result of a bad connection. Some heat should be expected based on the location of the plug on the roaster, but it shouldn't be so noticeably hot to the touch. You can certainly clean up the prongs on the roaster if they're dirty or rusty, but if the receptacles in the plug end are old and funky, those are tough or impossible to access to clean up. Either buy a brand new cord or see if you can find one that looks to be in good shape at a thrift store.
While the cloth covered cord provides a nice original look, you don't want your mom to be afraid to use the roaster, so replacing the cord is probably the right thing to do.
If there are any
INDEPENDENT, small hardware stores within 25-50 miles, they may have a new replacement cord set, or if there is a small appliance repair shop....I would do what I could to get a replacement cord set.
Otherwise, it looks like a winner!
Lawrence/Maytagbear
Also, make sure the connector prongs on the roaster are not corroded or darkened. If so, they should be cleaned with emery cloth to brighten them up to make better contact. It is not uncommon for the connector area to get quite warm.
Vintage Appliance Cords Getting Hot
Yes, normal and you should exercise all and extreme care when using vintage electrical appliances that generate heat. Many of these appliances would never pass modern UL or other saftey guidelines, and or would probably land their makers in court over injury lawsuits.
In order to replace the cord (which you should do by the way), you need to know the spacing of the prongs. Take the cord to any good hardware store, though you may have to search out one that has been around awhile, to find a certain match.
Other than the above, you can search eBay for "Roaster" or "vintage appliance" cords. There are several flavors, roaster, irons, coffee makers, etc, so again make sure what you are getting will fit your particular roaster.
Another thing:
Do *not* use oven cleaners, Comet or other types of cleansers, SOS/steel wool pads on aluminum cookware. It will damage the finish and hasten the breaking down of the finish.
WearEver (one of the largest makers of aluminum cookware and appliances), used to make a special cleaner for such things, but don't know if it is still sold/made. Cameo does have a cleaning powder for aluminum however. Other than these two there are various methods of cleaning aluminum using tartic acid or other substances. A quick "Googling" of "cleaning aluminum" should get you where you need to go.
Finally these vintage electric roasters, like many other portable ovens, hot plates and so forth from the time use quite allot of power. To be safe plug your roaster into an outlet (I prefer 20amp, but suppose 15 will do), with nothing else going at the same time on that line. As for the indicator light, it may be going from bright to dim as the heating coils cycle on and off. Again these babies take up allot of juice (just watch your electric meter spin when the thing starts heating),and depending upon internal wiring, the unit may direct as much power as possible to heating, even at the expense of the light.
ok... the light goes on and off as the roaster cycles (on when its heating, off when its not), but dims and brightens when is on. it does dim quite a bit, I had it sitting in the middle of the garage floor, plugged into a VERY heavy duty extension cord, and from normal standing position I could see it dimming and then brightening back up. I will check for a new cord at the hardware store tomorrow, hoping I can get one.
Extension Cords
FWIU it is *not* a good idea to use them with appliances that draw lots of power, something about loss watts or something the longer distance current has to travel. Would have to research the matter again as don't have the information at hand.
If possible try plugging the appliance directly into an outlet and see if things are better, light wise that is.
Dustin is the heating element the source of the indicator light that dims and brightens? Waffle irons used to have a jewel light that was illuminated by the heating element. Just a thought. alr2903
Sorry Laundress, i failed to completely read 474264, I think you are right on the money with the indicator light issue. alr
What you need to do..........
Is take the bottom off the unit and check the wiring for the indicator bulb. The wiring is probably rusted as a result of the humidity from the heat and cold the unit builds up from being used over the years. This happened with my '57 Westinghouse roaster. I replaced the wiring and my indicator bulb worked fine.
