To mee the cycle dial is out of sequence. Soak/pre-soak follow after the regular/heavy cycle as does Permanent Press after knits/delicate. Most Whirlpools I've seen over the years had soak/prewash or super wash and then followed with normal or regular/heavy. Now I will admit I vaguely remember some gentle or knits/delicate preceding Permanent Press. But to me, Kenmore always had it in proper order. Pre-wash or soak, then Normal, then Permanent Press, and then Knits/Delicate. Most intense first and gentlest last as you went around the circle;.
