Percolator Cleaning
ea56
Silver Member
Jun 16, 2014
9,356
Cotati, Calif.
I recently posted on thread #58904 about the Universal Coffeematic that percolators can be cleaned using dishwasher detergent. But I should have included the caveat that if the perc or any of the parts are aluminum the aluminum may darken by usinig this method. The Universal Coffeematic does have an aluminum stem and basket. In this case you can accomplsh the same ease of cleaning by using Cream of Tartar instead of the dishwasher detergent, Cream of Tartar will not discolor aluminum, and will in fact remove any discoloration or darkening of aluminum. To clean your percolator using Cream of Tartar first fill the pot to the max fill level with water, place the stem and basket in the pot, add 1 to 3 tsp. of Cream of Tartar to the basket, plug it in and let it run a full cycle. Now unplug and wait 20 to 30 mins. Pour out the solution and rinse well. Any remaining coffee stain can now be easily removed simply by wiping it off. You can safely use dishwasher detergent like I explained in the previous thread on any percolator or vac pot that is all chrome or stainless steel. This method works really well on Sunbeam Coffeemaster C20 thru C50 or a Farberware Superfast percolator. If you really need a deep cleaning on a perc with an aluminum stem and basket and the Cream of Tartar didn't do the trick (ie. you picked up an old perc with several years of coffee stain build up), go ahead and use the dishwasher detergent method first, then run a cycle with Cream of Tartar to remove any discoloration on the aluminum parts. I've tried this and it really works.[this post was last edited: 3/22/2015-19:08]
Half a dozen (or more) Polident tablets and a good overnight soak (hot water) does wonders. If you've got a badly stained pot you need to use <span style="text-decoration: underline;">several tablets, remember  you're not cleaning your removable teeth, and it may take 2 soaks. (added for "Doubting Thomas" Phil)...just kidding of course
 </span>
Martha wouldn't lie...
[this post was last edited: 3/23/2015-14:34]
Old and new Polygrip
I'm smiling at the friendly reminder, "use daily". Also, put on clothes after showering, not during, etc. When my dad was using this product, in a green tube, my mom accidentally grabbed it for toothpaste one morning. :-)
I have some denture cleaning tablets, which are good for lighter stain challenges. But, they didn't help much for the thrift finds(coffee percolators) with alot of staining.
I am not sure about aluminum, but the stainless steel interiors of 2 coffee carafes that we use, get quite nasty after a couple of weeks of use. I use a mixture of 50/50 water and household bleach. Let it sit overnight, a good rinsing and a wash with dish detergent and they look and smell like new.
Jon
A friend of mine uses Vinegar..
<span style="font-family: verdana,geneva;">He uses two parts vinegar to one part water in his aluminum percolator.  Let's it run through a cycle and gives it a good rinse.  He swears that keeps it clean and the coffee has a good taste afterwards.</span>
<span style="font-family: verdana,geneva;">I have always used a little OXY clean and very hot water in my percolators and had good success.  It's interesting to hear how many people have so many methods and the varying success they have with each.</span>
