valvashon
Active member
"Phil" is my now built in KitchenAid KDI-58. In good shape (I think) and painted something resembling Woodtone Brown. Phil has a temperature problem.
It's too low.
Phil isn't cleaning very well and I'm starting to get push back from the rest of the family. Here are the measured-with-a-heat-gun temperatures inside of Phil during a normal cycle. I did run the faucet of the kitchen sink until the water felt hot, then started the cycle. Inside DW temps taken at bottom front:
Water to start: 112° F
After first rinse, drained: 87° F
Second rinse: 106.5° F
Main Wash: 110.5° F
Rinse #1: 111.5° F
Rinse #2: 112.5° F
Water measured at sink nearest to water heater: 124° F
Water heater set at: ~140° F
Water heater is at one end of house, 40 to 50 feet of un-insulated galvanized pipe to get to the kitchen. At some point that will be addressed, but for now I'm thinking that a tankless water heater under the kitchen sink would be a good idea.
Any ideas on what gallon size to effectively provide hotter water to Phil? The BOSCH models will supposedly do 145° F which should improve the cleaning ability of Phil and I'm thinking a 4 gallon one would be about right.
Is this a good idea or is there some other way to get hotter water to the dishwasher?
Thanks,
Val
It's too low.
Main Wash: 110.5° F
Rinse #1: 111.5° F
Rinse #2: 112.5° F
Thanks,
Val
