Franklin/WH
That's correct, cfz2882. These were straight-vane Westinghouse models. I had one next to a GM 1-18 for dramatic effect in 2005 at the wash-in. Fun and splashy, but people who had GM 1-18s before must have absolutely screamed when they bought one of these. Though the control panel was the same, the cabinet was a quarter shallower, which was just a harbinger of disappointment to come. If the 1-18 held eighteen pounds and could deal with our king-sized comforter with ease, this machine rated more like fourteen pounds and the comforter would have been out the top of the tub and preventing the lid from closing.
These might have been marginally nicer if they'd used the Westy ramped agitator. The straight-vane was cute and had fun removable upper fins, since it had a lint cartridge in the agitator column as well (some did, anyway). As WCI metamorphosed through the eighties, the Westinghouse design and Franklin mechanism flip-flopped from top- and bottom-of-the-line, respectively, and closed out the eighties with the Westies being relegated to the bottom of the ecosystem. Some truly ugly Montgomery Wards machines of the time had a black ramped agitator and plastic tub, with only a timer dial. By the late eighties, my Frigidaire was a Franklin, with the lame little PerpetuaTwirl agitator with four very short, curled-at-the-skirt vanes that worked with the indexing tub to twirl, twirl, twirl the load around and turn it over maybe once in fourteen minutes.
Both the Westinghouse and Franklin incarnations were an absolute pain in the ass to work on. It took me two days to finish replacing the belt on my Franklin, after using fascinating new obscenities I'd never even thought of before. The Westinghouses were full of incompatible metals that went into aluminum housings, so you were sure to shear off bolts everywhere you worked. They also glued the hoses to the pump and tub fittings even though they additionally used clamps, which I never understood, and made working on them completely frustrating.
The Franklin design put the pump (and water) on the underside of the motor, but Westinghouse perched the pump on top of the motor and put a plastic shield under it just-in-case. Stellar design.
We found a few of these over the years, and tried to strip them for parts when they failed, but they crumbled in our hands and ended up in the trash.
