brucelucenta
- Joined
- Jul 21, 2013
- Messages
- 1,924
Interesting looking machines. I have worked on and used these older front loaders in the past. They were adequate for the most part. In a commercial laundry setting, they came in handy for small loads of dark shirts and such. Since the laundry is pressed while damp, you cannot have any unsightly lint or redeposition that would press into the garments. They were quite good about that. Even tumbling in just one direction, they worked fairly well unless you had a larger item or too big of a load, then it rolled up into a ball. They also were so small in capacity, that the drum did not drop the clothes at a far enough distance to really clean very well if something was really dirty. Other than that, they were not bad machines. They extracted a little below average, about like the old belt drive kenmore & whirlpool washers of the same era.
