POD 4-3-2023
maytag85
May 11, 2017
3,117
Sean A806
This particular Lady Kenmore dryer appears to be from either 1974 or 1975 and I believe jons1077 has this dryer paired up with his 1974 Lady Kenmore washer. Looks to be a well designed dryer as it’s a Whirlpool 29” dryer which is made to this day but the only gripe I have about this particular design is the lint screen plenum tends to accentuate lint at the bottom which will choke down airflow if not cleaned out at least once a year but other than that particular quirk, it’s a good design.
Ahh. Thought it was closer to 1974 or 1975 judging by the avocado color. Though I believe there wasn’t many changes made between the dryer in the POD (with the exception of drum size) and the one in 1974/1975 since they had the same if not similar electronic dry control.
