POD 8-11-15 1957 GE Washer and TIDE
tomturbomatic
Gold Member
May 21, 2001
21,849
Beltsville, MD
You could get away with using Tide in the solid tub GE because the suds just floated over the tub rim and into the sump. During the drain, there was a pause after the water had been spun out of the tub to allow the suds to dissipate a bit. When CU first tested the new V12 GE, they showed a picture of the oversudsing that resulted from using a high sudsing detergent and warned that only low or controlled sudsing detergents be used in the newly redesigned machine.
