Hi Darryl,
From cold to 140deg, you generally allow about 45 minutes with a 2400watt element. To start heating, you push the white button next to the temperature dial. So I generally let it tumble for one increment first, then start the heating which stops the tumbling. So you basically get a soak from Cold to hot before the cycle continues. There is a nipple available to connect a hot fill hose to the machine, but that is a manual process. You would turn the tap on and fill it to just below the hub on the drum, then turn the tap off.
Hi Tom,
Rinso was a high sudsing detergent, the instructions suggest less than 1/3 cup of detergent and only until you see some bubbles on the outside of the drum. To add clothes to the drum once its started, you turn it off at the power point. The timer only cuts power outside the cycle, it has no in/out on/off position otherwise. The machine tumbles in one direction only and the tub doesnt stop through the cycle, just the speed changes. From memory, the spin speed is about 250rpm although I'd have to find the service manual to confirm. It is bolted down on all 4 corners of the machine, with half inch bolts. With that level of both down, I've never had it vibrate badly during a spin.
