Pork Shoulder, Italian Style (as requested by jetcone!)
turquoisedude
Aug 8, 2007
10,581
In a thread about my latest dishwasher project, the KDS54, I made mention of a smoked pork shoulder (aka picnic shoulder) that I used to dirty up some pans for a wash-test (see link below)
Well, here's the recipe.  Don't be shocked that it's from the 1965 edition of the BH & G Meat Cookbook.  The book belonged to my late mother and I swear she never opened it.  I snatched it when I first moved out of the family home in 1985 and I've been referring back to it ever since!
Italian Picnic Shoulder
1 whole picnic shoulder, 5 to 7 pounds
6 to 8 cloves garlic
3/4 cup vinegar
Remove skin and any netting from picnic.  Peel & slice garlic cloves in fourths lengthwise.  Cut vertical slits about 1/2 inch deep in meat and insert garlic slices as you remove knife.  Place in large kettle, cover picnic with water, then add vinegar.  Cover and simmer about 2 hours (allow 20 minutes per pound).  Remove from broth.  Bake in a slow oven (325 degrees) for about an hour longer (allow 10 minutes per pound).
Note:  I don't discard the broth - I soak white (navy) beans in it, then add carrots, celery, and onion to make a bean soup.  Yes, I am the consummate cheapskate... LOL
http://www.automaticwasher.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?59196__0#start_59196.820734
Since im a HOGAHOLIC!!LOL
This sounds wonderful, we live near Lexington NC which is the BBQ capitol of NC, so of course pig is on the menu at least once a week......
Paul,
That recipe sounds good. I think I'll try doing the garlic like your recipe the next time I smoke a pork shoulder for pulled pork.
When I make mine, I inject a brine solution into the meat two nights before cooking and put it in the fridge. The next night I drain it and put the spice rub on it (I like Salt Lick rub) and refrigerate until the next morning - I'll imbed the garlic in the meat when I do the spice rub. The next morning I wrap it tightly in foil and cook either in the oven (in the winter) or on the smoker at 275* for an hour per pound. I then unwrap it carefully (lots of juices form), get a smokey fire going on the smoker (I like hickory and cherry wood) and put it on the smoker for an hour or so at 225* using the juices to baste it every 20 minutes. It gets a good smokey flavor in an hour. BBQ purists don't like the fact that I use foil. They think I should smoke it for the full time but the meat stays so juicy and tender my way that the hamburger buns I serve it on are almost tougher than the meat. I hate buying a pulled pork sandwich, biting into it, and having the sandwich come apart as I try to bite my way through a less than tender piece of pork.
This pulled pork also makes an excellent hors d'oeuvre: simply serve small amounts on crackers, it is really good.
Brine Solution
In a two cup measuring cup combine:
1/4 cup sugar
1/4 cup salt
Equal amounts of apple cider vinegar and water to bring level to 2 cups.
Stir to dissolve sugar and salt and inject into pork shoulder with a Cajun injector.
