Potscrubber
Parts should, like the pump seal, be readily available for many years.
As for cleaning? I've never experienced a Kitchen-Aid yet, but according to this forums memebers its second to it. I've had a lot of fun with the GE I have and it cleans very, very well.
Holy Crap !!!
Wait till Bob (appnut) sees this and Ken too.
I think this is one of the Holy Grail GE machines that can take the rust off a trailer hitch.
And is the Two Wash Arm machine ?
I'd grab it. Wee bit noisy, but a great performer. Rapid Advance and all...
This dishwasher is identical to one my parents had. It actually cleaned pretty well for a dishwasher without a full size spray arm under the top rack. It has the shower tower set up that GE had for many years. It is about an '81 vintage, since that was when they built the house.
That is a GSD1200,  the same one I had.  It cleans rust off a trailer hitch.  Multi-Orbit wash arm (changes water pattern over time as it continues to revolve).  I got mine May 1987 and mine had red lettering.  My mom got hers about a year or year and a half later and hers had the white lettering like this one.  I'd get it.  I think Kenmoreguy64 has one too.  He's one that's collected several so he will have parts to keep his going. I still miss mine.
Based upon the buttons pushed, the last cycle used was Energy Saver wash and heated dry.
No, this doesn't have the little whirlybird wash arms at the end of the two arms.  That design came out mid-1990s.
Eddie, that was only part of the PotScrubber II series and only the two TOL models--GSD1050 and GSD950.  And from the early to mid-1970s.  The first version of this GSD1200 had PotScrubber III emblazzened on the control panel and is immortalized with Debbbie Reynolds' magazine print ad campaign.  That was like 1980 or 1981.  The 1200 was the TOL until GE introduced the electronic control 2000 series.
I just know that the one my parents had was about '81 or '82 vintage and did not have the "multi orbit" lower spray arm and no spray arm under the top rack. It looked just like this one on the outside. From what I remember, GE did make a model previous to this one which DID have a full size spray arm under the top rack for a short period of time. I have no idea why they stopped making it and went back to the shower tower, but they did that for several more years before finally making models with a full size spray arm under the top rack. This one had a visible timer dial and rapid advance timer.
I had the Kenmore version of this dishwasher back in the 80's...Great machine and could clean anything thrown at it. This dishwasher does not have a wash arm under the upper rack. It uses a Power Tower that does clean rather well any items in that upper rack. This dishwasher holds a ton of dishes. The Super Upper rack is tiered and was by far the best upper rack I have ever had the pleasure of using in a dishwasher. Even the lower rack I did love. Even with the cut out for the tower, it held a lot vertically. I always loaded plates on the left side and pots and pans on the right side.
This dishwasher should have the MultiOrbit wash arm in the bottom that changes the wash pattern up. This dishwasher moves about 35 gallons a minute thru 13 total jets...7 in the bottom, 2 in the middle and 4 in the PowerShower on the top of the tank.
If these dishwashers were still made today I would have one.
GE Potscrubber DW From The Early 80s Till the early 90s
With food filter and Multi-Orbit wash arm, these were by far the best performing DWs GE had ever built up to this point.
They still had a few serious flaws however, they did not have a spray arm under the top rack so the lower rack so the lower rack had to be loaded with some care if you wanted every thing to get clean in the top rack.
These DWs also had a very restricted lower rack which really limited capacity, and they used their crappy 1/6HP shaded pole motor that was also used in the cheap builder DWs that GE was famous for. These motors not only had a noisy fan and you could also hear the annoying sound of the motor speed varying as the pump was washing.
All that said these were pretty good DWs, and about every part you might need is still available except the timer and the program switch, but luckily these did not fail often.
John L.
Pics of the machine. I have since wiped it down and ran citric acid with cascade complete through it. I have a load of dishes in it right now.
First impression
I'm not impressed with the Potscrubber at all. I loaded it with mostly clean dishes, I could hear the water swooshing around inside. Both top and bottom spray arms are turning freely. When I opened it up after potscrubber cycle. I found the dishes just as dirty as when they went inside.
Wow!
These things can whoosh and move their arms when there is still a malfunction, so don't be discouraged.
First off, even Consumer Reports was forced to admit that these cleaned better than KitchenAid. We've had a few (and currently have one) and, quite honestly - they are the best dishwashers for cleaning dirty dishes on the American market.
Hands down. The Best.
Clean much better than any of our KitchenAids ever have.
Now, if you're interested, there's quite a bit of easy stuff you can do to make her work great again.
But - a warning: These are notorious for holding on to invisible slivers of broken glass in the sump and in the various filters. I suggest caution. If you like, I can post the most common things to clean out and check - none hard, none arduous, even if something were to be broken, it's all still available and cheap.
Let me know - this machine may be in a bad mood at the moment, but she's one of the best ever built and is the best at cleaning dirty dishes, period. The multi-orbital arm is so good, GE has 're-invented' it for their current top of the line series.
Please post anything you can about it. I know I need to find 2 door springs cause the ones I have are rusted and I need new exterior insulation. Can't wait to get it going cause right now my Dish Drawers are washing circles around it.
Cleaning Problems With A GSD 1200 Style DW
What type of soil is being left on the dishes ?
A good test of any DWs water distribution and mechanical cleaning ability is to put in along with a load of dishes several glasses with peanut butter smeared inside the glasses in various parts of the top rack including the corners, and see if it is all removed.
The most common problems with these DWs as they age are.
1 Under filling, usually a bad inlet valve [ water should cover the floor and be up to the main wash arm hub when fully filled for main wash. ]
2 Broken food chopper [ this was a very cheesy affair ] if this is not functioning water circulation will be very poor.
3 Drain valve in pump letting water leak past and then the DW looses water to soon, [ replace complete motor and pump, not a bad idea in any case to update pump and motor to newer style ]
4 Bad drain valve under filter screen in back of tank, remove and inspect, replace if deteriorated.
Overall these DWs can clean very well if loaded correctly, but they are nowhere as good as standard tub WP Power-Clean and KM Ultra-wash DWs from 1985-2007, see my post on my WP PC DW, and a typical load that is run several times a week for almost 30 years with hardly ever a problem.
John L.
Cleaning and repairing
Actually, this dishwasher, with it's muti-orbital arm does a better job cleaning that anything else, but, heh - some of this is religion, so let's focus on what needs doing. I know it takes a big man to admit GE could do anything right compared to KA (and I'm the only person here who isn't in love with KA), so kudos to John.
So, John hit the high points. Here's what I'd do:
1) Check for the rather large sheet of paper tucked away (usually under the kick panel) with schematic, timer settings and instructions on how to remove and replace the sump, motor, filters, etc. If you have it, that's all you need to clean and check those areas. If you don't, the literature is in the library here. Without it, it's way too complicated.
2) Lots of little holes in the multi-orbital get filled with junk, and on some (not all!, dratted GE), you have to turn one tower of power mount the 'other' way to loosen it.
3) If the soft-food disposer is missing or thoroughly bound up with plastic or wire, it is a good idea to change it out. If the motor is long and black and there's no capacitor in sight, John's advice is good if you want to make this a daily driver. If it's kind of square and grey with a capacitor (especially if it says "SIEMENS" on it, just the rebuild kit will do fine.
4) There's a little valve at the back, under that large filter which can get gunked up. Cleaning it will make an enormous difference in performance as it lets the dirty water out. Or, if it fails, keeps it recirculating.
5) Super caution is called for when fishing through that sump. The filter is big enough to keep a VW Microbus out as one aficionado here has mentioned, but not much else - and slivers of glass are a serious danger.
6) The inner door comes off easily and make cleaning fast and easy. The two black (sometimes grey) pieces of more or less pliable rubber at the bottom corners of the door lift out for cleaning, too.&#92
7) Two sounds to listen for:
a) Close the soap door and run the machine. Does it open (you'll hear it)?
b) When it drains, is there a solid 'thump' and water drains out with a lot of force? If it's only a weak stream, then you've got blockage or the pump needs replacing. If there's no thump, then either a spring has come off the solenoid package for the drain or the solenoid has failed.
The door springs were used on models both before and after this one, you can grab them at any repair shop or clean them up a bit. Exterior insulation can wait until the rest works great. It must not block airflow, but was pretty extensive, you can see photos of it in our archives. Virtually all parts are available either at online appliance shops or can be had from other GE Dishwashers, including the ones of this series still on sale, new.
If you do have to replace the water inlet valve, make sure you don't disturb the overflow protection system. It's easy to pull out of position (kind of the point). Cleaning that whole assembly can't hurt, either, but pay attention to how the heating element is held by that stainless steel strap first, it's non-intuitive (or, I'm too D-U-M to get it right without pictures).
Hope this helps. Best dishwasher there is.
