Preparing Whirlpool apartment washer/dryer for use
vintagemh
Nov 28, 2019
15
Saskatoon
Greetings! We are back to working on the motor home and got the washer and dryer we purchased for them into the coach. I did try them before we put them inside and they did work and complete a cycle with clothes. Now that they are inside and before we start building cabinets and steel frames with slides to accommodate them (pulling washer out on slide to load it) is there something we should to do prep these machines for use? We will not be using them regularly but once in awhile. We were told they had little use, and when we did try them they didn't make any weird noises but they did "smell hot" like maybe 40 years of sitting dried out the grease hot. Are there any instructions for doing some kind of service and inspection before we move them into the permanent homes, moving them back out to service them isn't going to be easy so would rather address any issues now.
Thank You!
Loren
If it were me I would at least take the backs or fronts (or wherever the service panels are) off and check the innards, vacuum them out, look at belts and hoses to check for cracking, etc.  40 years is a long time and rubber can get brittle.  But that's just me.
Mounting on a slide
Hi, that's a great looking set. Congrats!
This style washer was Whirlpools first series of portable/convertible washers. It is a much heavier unit than the later series. It is actually a 24" belt drive unit with front mounted controls. The suspension on this machine hangs from the cabinet top. As such, it may not be stable on a "sliding" platform if/when it goes out of balance. The machine is designed to be on a solid footing. Not sure how your designing the platform, but it would be something to consider.
John L. would know better about this.
Good luck and keep us posted!
thanks everyone
I'm going to fabricate the slide myself so I'll make sure its just like a floor with something that locks it in place, don't want it moving around when we are under way. I was thinking there was some kind of thing I could put in the tub so it doesn't move around. But thank you all for the help. I'll post pics as I take off the covers and build the stand so you can verify that will suit the need. Machines are the same year as the coach I believe, 1978.
Best of luck with your beautiful avocado babies. I would suggest a thorough inspection with preventative maintenance before installing them. It's easier to avoid trouble than have to deal with a breakdown or leak or worse after installation.
Safe travels to you both.
Cool 70s WP Washer & Dryer
If these work fine I would just start using them, there is really no preventive maintenance that is easy to perform especially on the washer.
If they both run fine without unusual noises leaks etc just enjoy them, since they will get very light use they may last a long time.
This is the later belt drive WP compact washer with a nearly 900 RPM spin, this washer is a good choice and should have no problems with excess vibration as it was designed to operate on wheels. the fast spin speed will allow the 120 volt dryer to do its job much more quickly.
John L.
Motorhome Lust
From the first time I saw one of those GMC motorhomes at Lake Tahoe in 1979 or 1980 I was smitten.
It still looks great and "contemporary" today.
It was a design that was WAY ahead of its time.
BEAUTIFUL motorhome!
Wow!
I have no advice to offer.
I just had to say; that's a beautiful laundry pair!
And that GMC looks stunning! I've only seen one, maybe two in person in all these years.
Best of luck with all of them!
Barry
Wow! Fantastic!
Please post pictures once they are installed.
The hot smell is normal as I noticed these whirlpool motors heats up more than others and dust collected on them during the time is the hot now that will just disappear as they will be used.
The only suggestion I can give you is to use the machine for more loads not one only and for a while a week or two to see if it's reliable and won't develop any leaks or issues.
Another suggestion i can give you is that you may want to have the tub still while traveling, say narrow curves or steep climbs or a sudden brake ,you can fabricate a styrofoam tub block holding tub collar ring and a hole for agitator in the middle to hold it,a thing you can slide in when not in use and dry.
They were used for transportation when brand new.
Kenmore portable
Good morning Loren, welcome from over the big pond, the Kenmores and your Coach look absolutely fantastic, what a way to enjoy travel and to do washing, looking forward to seeing how its all checked out and installed.
We had the washer version badged here by Servis UK for a short time but not in the beautiful colorway..
Enjoy & Cheers for now , Mike
The dryer...
If felts are okay, no roller or tensioner is squeaking and completes it's cycle without over heating then it's fine.
Clean it from lint and you are set.
Dryers usually outlast washers as they are simpler appliances and very few things can go wrong with a dryer.
Make sure to have a vent installed in the frame-closet you will build, for air intake.
Whirlpool was very specific for minimum installation in motor-mobile homes giving all clearances written on their lids...
But i'm sure few followed those requirements.
I never knew those compact Whirlpool washers had a 900 RPM spin. I had lots of friends who had those growing up in NYC because they were perfect size for apartments. Now I want one. Was the spin speed also 900 for the 24" wide Whirlpool top loaders that had the same innards as the compacts?
Great looking Whirlpools and mobile home. Could you get a picture of the interior of the washer tub and agitator when you get a chance ? Thanks.
