Pressure Cooker TIPS 'n' TRICKS: a companion to the current Pressure Cooker thread
joeekaitis
Bronze Member
Dec 22, 2001
1,773
Rialto, California, USA
If you're an experienced pressure cooker chef, share your wisdom with the world. And away we go!
ALWAYS perform the Peek-A-Boo check of the vent pipe. If you can’t see through it, steam might not be able to get out. Clean it with a toothpick, pipe cleaner, stiff wire or try to blow out the obstruction.
NEVER squeeze the upper and lower handles together while the pressure cooker is coming to pressure or has attained pressure. If the safety release closes too soon, the cooker will overheat before attaining pressure and scorch the contents. If you have to move the pressurized cooker to a cold burner, pick it up by gripping the helper handle and lifting the main handle with your palm up.
Wipe the pot's rim with a clean damp dishcloth before you put on the lid. The tiniest speck of ingredient residue can prevent a proper seal.
Modern silicone gaskets can be washed in the dishwasher with a phosphated detergent like Bubble Bandit, Cascade Fryer Boil-Out or Bright and Fresh. Phosphate-free detergents are either too caustic or acidic and can dry out or corrode the gasket.
Don't oil the gasket before putting it away. Instead, lightly oil it right before you close the lid. This will have a "seasoning" effect and will prevent the oil from turning gummy due to oxidation.
Your turn, World![this post was last edited: 4/13/2015-13:42]
For cookers with jiggling weights, the hissing sound of steam escaping should only be coming from the vent pipe.  If you hear or see steam escaping from anywhere else, something is amiss and the cooker will likely not reach pressure.
Gram always said to...
Pull the gasket out every so often and clean any Gunk that may collect between the lid and where the seal seats.
And Yes. Always run hot water on the lid upside down and make sure water pours through the Vent Pipe.
I just made some Short Grain Organic Brown Rice in the 1940.
Saute a small diced Onion and 1 clove of Garlic diced as well.
Add 1 cup Short Grain Brown Rice, 2 cups Chicken Broth, pinch of S+P Mix.
Bring up to pressure and cook 40 minutes.  Let pressure drop to it's own accord... Before serving, I like to add 1/2 cup grated or shredded Pecorino Romano. Or More.  For creamier Rice add a shot of Heavy Cream or Chicken Stock.
