Pretty please some one help
konnie
Nov 27, 2009
Hello
I have inhertated this wonderful, Simplicity supetwin wash machine..
But I have absoultly no idea how to use it.
The agitator works, but I don't know how to get the silly thing to pump the dirty water out, and the spinner: well you can hear it turn on but it doesn't want to spin.
Someone please help i need clean clothes.
Thanks
K
This is about a Hoover TT; don't know if Simplicity is t
First, either find out yourself or have somebody help you to make sure that the belts are on for the spinner and the pump. (I'm sure you know that you have to close the lid on the spinner, yes?)
See if the spinner will rotate easily by hand; if it flies fast and loose both ways, the belt is off.
Look for a control dial or switch that shows "Wash" or "Drain" or something to that effect, and make sure you have "Drain"selected to pump the dirty water out.
Hope this helps. Maybe somebody else has a Simplicity, and will know better than yours truly.
simplicity?
I have never seen or heard of a simplicity twin tub. post some pics and im sure you will get more help.
Greetings from Hamilton...
I have the same machine in Harvest Gold! There are two places you can place the knob in to get it to drain. 3 o'clock and 9 o'clock. One is drain with the spinner on, and the other is to drain the wash tub and the spinner.
As for the spinner, maybe there is some clothes (socks, underwear) caught between the perforated tub and the solid tub. When I got mine, there was a whole pillow case wound around, but the spinner still spun. If you apply pressure to one side of the spin can, and stick a flashlight in, you might be able to see if anything is trapped.
Guy
