cfz2882
noticed when running my 2009 GE hydrowave(3.2 plastic tub version)with the front off there is a little green LED on the motor inverter that is lit when the washer is "off"-thinking about plugging into a switched outlet so that washer is all the way"off"when not in use in order to protect electronics from possible spike/surge damage.Now have to check if my Neptune 3000 is all the way "off" when inactive...
