askomiele
Hi out there!
Feels a bit strange to post my 'help questions' around here but I have a problem.
Last night when I was doing laundry, at the end of the rinsecycle the pump form my Miele didn't kick in. After a minute or 2, I stopped her and let her 'rest'. Afterwards I started the 'drain' program but no sign of live on form the pump. I did empty the tub manually, open the pump with a clean filter, and spun the impeller by hand. After closing her up she spun and proceeded to the last rinse. Yet again the problem re-occured.
Sometimes, the machine gives the command to start the pump and the pumpmotor kicks in only after seconds and not immediatly like it used to do.
I had similair problems with my olympia, but that problem solved itself.
Is it possible that the cold weather is causing some extra trouble? It's not freezing and yet againg I used my Miele is a much colder environment without any trouble.
Suggetions?
Suggetions?
