Question For UK Members - American Style Top Loader Availability in The UK
chrisbsuk
Aug 21, 2006
339
Bristol, uk
Hi all,
I hope you've had a great Christmas so far!
I wondered if any of you could help - my partner and I have a couple of Airbnb places here in Bristol, which we obviously have to go in and clean after one set of visitors leaves, in readiness for the next set.
Currently using my Siemens IQ500, which whilst is excellent at washing all the sheets and towels generated, it is just a little too slow - even with Speed Perfect selected it'll take around 1:10 to do a 60*c cycle, and I find the final spin is too short - hence time lost in the dryer. As it'll be full, the normal 60*c cycle will take the full 3:25 - time we don't have 😔
My gut feel is that I need an American Top Loader, because of their incredibly quick cycle times and fairly large capacity - this will compliment the Siemens machine. That is going nowhere!
Are any of you able to recommend a store here in the U.K, that still sells these? Looking through the Internet it just seems to be the Whirlpool brand with the crappy base impeller rather than the whole length agitator available here. I'd like one that still uses proper hot water, and lots of it! And the proper agitator.
Any thoughts? I'd really appreciate any guidance you could give - I'd also be happy with a 2nd hand one to be honest - although on searching eBay there isn't much around at the moment. Maybe you guys have some contacts?
Thanks very much and enjoy the rest of the holidays,
Chris
If you really have that much laundry, a used Miele Professional might be the better bet. Or ELux, though they seem more prone to failure.
They run a full 60C cycle in just under an hour, even shorter when hooked up to hot water. Further, they have a far far better extraction rate then any TL washer would have. I mean, if a 60 or 120 second 1400rpm extraction is not enough for you, 800rpm sure wont do the trick.
Maybe a dryer switch would be a good idea. A nice big industrial one that could handle 2 loads (Siemens + other machine) at once. And given that any UK house I visited had a gas supply, a gas dryer could save a lot time and cost.
If you want the non plus ultra and would be willimg to invest, a Miele OctoPlus set would be the perfect solution. 8 or 10kg capacity, a gas dryer, and a full load washed in 49 minutes, dried just as quick.
Or, a little cheaper, ELux released these MyProfessional machined a little while ago. I think they retail for 1500€ new here in Germany, and their 60C cycle on a hot connection is something like an hour as well.
Hi Chris,
I second that, if you're trying to dry a load from a US Tl in a European dryer they dry times will go through the roof. If you can, get a large capacity F&P Tl with the agitator, that spins at 1000 rpm. Just be aware that you'll need 100l hot water per fill and if your hot water pressure is low, be prepared for a hot fill time of up to 10 minutes before the cycle starts.
Anything slower than that and if you're using a condenser dryer be prepared for dry times to take 2-3 hours and you to potentially need to empty the container once during the cycle. Ask me how I know :)
The other option is a standard Miele and program it to AU mode. A short cottons 60 cycle takes 56 minutes or 1.06 with extra rinse on. A 50deg cottons cycle on short is only 40 mins
Cheers
Nathan
Just to chuck my thoughts into the mix. . . .
I had a Whirlpool American T/L that seemed like a good idea last year with such a large family. It is a completely different way of washing than what we are used to. If you bung in something with a stain and set it to hot chances are it won't come clean without pretreatment of some kind. The wear on the clothes was also noticeable. Fill times (especially hot fill with lower pressure) was v e r y long. Second rinse for us was also a nessecity. Spin performance wasn't brilliant hence longer drying times. I thought it would save time but it turned out to be more labour intensive and slower.
I kept the matching Whirlpool American dryer as I can fit nearly two loads out of a standard Hoover f/l. It is a brilliant dryer for most things apart from sheets which it balls up. (No pun intended 😀). I am looking for another standard UK dryer to sit alongside side with reverse tumble just for the sheets.
I'm sorry if this ruffles any feathers from our friends across the water, just speaking as I experienced.
Hope this helps.
Look for an Fisher & Paykel Top loaders
Look round to see if any Expat Aussie or New Zealanders are selling their toppers.... they are on same voltage as UK. But as everone says they need a large hot water tank or an instantaneous water heater (power shower heater?) to supply the needed hot water.
We had a 7.5kg top loader on a 200L gravity fed hws and it took up to 15 mins to fill on a hot wash!
Guys,
Thanks so much so far!
In terms of water pressure and supply, that isn't a problem as it'll be connected to a combo boiler which as you know makes hot water on demand - the washer will be next to it.
Hadn't thought on the drying aspect, but now I do I can't have an American dryer as the machines are in a basement with nowhere to vent to - currently use a Siemens condenser dryer, on the rapid cycle, which takes about an hour (after a 1600rpm final spin!)
I've started to "watch" that Miele Professional machine! Maybe that is a better option - I thought the rapid cycles on a top Loader may have been a good solution. 😊
Thanks again all,
,chris
Hello Luv!
An Americans advice if you can stand to it; top loading automatic washing machine may or may not solve your problems regarding bed linen.
Have owned used all and sundry; top loading automatic with central beater, Hoovermatic, 5kg capacity European front loader (Malber, Miele, AEG OKO-Lavamat), Maytag wringer washer and finally tubs, mangle and a posser, and am here to tell you each have benefits but also negatives.
The five basic rules of good laundry (wash contact time, water temperature, chemical action, mechanical action, and water level/amount) are constant. Where one is decreased the others must be raised to compensate, and vice versa.
Because top loading washers with central beaters use more water and stronger mechanical action they do hold out the prospect of faster cycle times; but at the cost of injuring items after repeated washing. Also because the chemicals are diluted with so much water stain removal isn't often what it could be. Traditionally Americans have gotten around these various shortcomings by using large amounts of chlorine bleach.
Yes, top loading automatic washing machines *are* faster. But this can come at the costs of increased energy/resource use and if not careful wear upon your linens.
Capacity of such machines is deceptive; one would think they hold more than a 5kg rated front loader, but this not universally true. Often just two large sheets and a few pillow slips is all that can be managed. What you want is for things to turn over in the wash, not merely get thrashed about by the beater.
Common to many top loading washers with central beaters is the occurrence of air bubbles when doing linens. Things just then bunch up and won't get drawn down into the wash.
Doing wash in an American top loader is going back to how your gran or great-gran did the laundry. Stains must be treated and or things pre-washed/soaked before going into a hot or even too warm wash. Otherwise the heat of water will "cook" in certain stains binding them to fabric, this will make them that much more difficult to shift.
It is worth nothing even here in the States commercial laundries most always went with H-axis (front or side loading) washing machines, this going right down through the years. Laundromats were probably the only places that used top loaders and today even they have mostly gone over to front loaders.
What you want is either a fully or quasi commercial washing machine with a bit larger capacity than a domestic, and faster no nonsense cycles. If you want something "American" I'd look for a Maytag *Neptune* or perhaps another fully or quasi commercial front loader. Maybe something used from a laundryette supplier...
http://www.ebay.co.uk/itm/Primus-FS...452059?hash=item4b0dc3541b:g:7BEAAOSwnH1WXxHu
Here launderette washers complete a full "normal" cycle in about 30 minutes. Cycles generally are: short pre-wash, main wash, two, three or four rinses and then final spin. No heating of water so you need a good and powerful supply of hot from the taps.
While there is absolutely no doubt in my mind that top loaders have the fastest cycle times when it comes to doing a load, I've personally found that the overall cost of operation just simply isn't worth it. More water, more detergent and eventually more frequent replacement of garments and bedding.
While I can't say I have as much experience as Launderess, I personally can attest to having my sheets ripped with small "L" shaped tears and my comforter slips torn at the slit because they weren't buttoned up. Yes, I admit that this was probably user error and the wash speed was too high for the fabric. These are elementary mistakes someone who isn't familiar with a top loader can make.
One big problem I really disliked is how my sheets would just bubble up and then move back and forth during the wash cycle, with portions of the sheets not getting cleaned. I felt the only way to get them clean was to use to occasionally use a wooden dowel and "punch down" the bubbles so the sheet would get cleaned properly.
If you want to do a lot of laundry at once and speed up the time it takes to do it, I'd just recommend getting a fairly large front loading machine. In saying that, I can recommend Huebsch machines for this purpose. I'm sure they sell them in the UK.
Laundry
Hi Chris, great to hear the Siemens IQ is still pride of place, sounds like a good idea to review laundry practices, depending on just how much you are doing etc, is it 2 / 3 bed & bathroom sets per place or just 1 from each ? personally I think you have the best set up in terms of wash result with a profile wash front loader, the speed comes from the extraction rate, drying said item and the finishing i.e. do you need to iron the bedding etc..
I used to need to process 6 bedrooms sets (duvet cover, bed sheets, valance, 4 pillows) and 3 bathrooms (12 bath sheets , hand towels, bath/shower mats) and the best set I had was the MaytagAsko`s, had a mix of lightweight and damask bedware, tried a hotpoint top loader but stuff floated around and capacity wasnt great, I found by folding stuff and using a separate spinner I could cut down on drying times, I also used timed drying so say after 20 mins I could pull the bed covers out the dryer and hang them over large rail and they finished without creasing.
It may be an idea to buy more spare bedware and towels to avoid the stress of a quick turnaround and perhaps look at a local setup that could wash n dry for you, its all about the cost overheads, time and how much you want to be involved - although I guess on that score you just ordered the Little Giants ha ha.
Let us know what you do and how it works out for you !![this post was last edited: 12/31/2016-09:00]
Thanks all..
Happy New Year everyone!
Thanks for your replies- sorry for the delay in my reply, I have been travelling back to the UK from Thailand!
I'm going to go with a Top Loader for now (don't all go mad!) to supplement my current FL set up, and see how I get on - if it proves to be more trouble than its worth, then I'll get a Miele Little Giant Pair (I blame chestermike for that suggestion!!)
I've found a Whirlpool TL on Gum Tree - a few years old, never used, still in its box - so I'm going to get that, and take it from there.
Once its set up I'll update you all with some pictures!
Looking forward to talking to you all soon
Chris
I do rather wish
UK members would stop being so exclusive. It's something the South Americans, Australians, New Zealanders, Italians, Dutch, Germans, Czech and Scandinavian members don't do.
That said - there are a lot of US Military bases throughout Europe which use Speed Queen top loaders. You're probably going to find parts for that brand a bit more easily than for any other American brand.
Now, having grown up in Germany and spent a good part of my youth with relations in Scotland and Ireland: American top loaders pump an enormous amount of water out of their gigantic tubs all at once. You might want to consider a laundry-sink to catch the truly massive quantity of water.
As for the dryer..
Most American dryers are in basements and are vented. Get a masonry bit, a cold chisel, and start chipping away at an outside wall, a vented dryer is much faster too.
