Repairing a Frigidaire unimatic
jessed
Jan 11, 2017
147
Saint Marys, Pennsylvania
I am glad to say that I finally got myself a Frigidaire unimatic washer.
I bought it knowing that it had an issue. It is supposed to be leaking around the motor. I am kinda thinking that it might be the bellows but I am not sure. I need detailed directions of how to take the tub out and check the bellows and the insude.
Please help!
Thanks,
Jesse
Congrats on your new Unimatic. What model do you have?
There are service manuals for Unimatic washers in the Ephemera Library, you'll find lots of detailed guidance there.
If you describe or take a picture of where the water is coming from, we might be able to narrow that down a little more. There are several places leaks can originate, but the bellows wouldn't necessarily cause water on the floor.
http://www.automatice.org/cgi-bin/index.cgi?brand=Frigidaire=AW
It is the 1954 WO-65-2
I am not sure exactly where it is leaking because I have not had tome to get around to checking yet. I was told that it is leaking down the side of the motor.
Thanks,
Jesse
You'll have to see where the leak is coming from, if it's running down the motor could be leak around where the rubber mechanism support seals to the cabinet base. A coat of silicone would cure that easily. Or I have also seen where the screws were not tight enough and simply tightening them fixed that issue.
Let us know exactly where the leak is coming from (with a picture please).
