Repairing another LW-11 General Electric wall refrigerator...
turbokinetic
Jun 23, 2018
906
Northport, Alabama USA
Some have probably seen my post a few days ago about a yellow GE wall fridge. This is the second one in a week and it's a different unit just to be clear. (Note: here is the first thread: https://automaticwasher.org/threads/ge-wall-fridge-lw-11-repairs-this-one-was-a-mess.99213/ )
GE changed the design of this fridge over its short production run. If I'm not mistaken, the first year of production was unique in several ways; including use of a weighted valve in the refrigeration circuit. This valve helped to allow one compressor to power two different evaporators working at different temperatures.
This fridge was bought to replace a unit which was lost in a restoration shop fire several years ago. It was bought non-working with the infamous promise that "it needs a simple fix." A tech was called to look at it. He installed a new power cord and fan motor, and then 'noticed' that lines had been cut. He declined to make further repairs after this 'discovery.' Upon inspection of the fridge, it was clear that the line had broken, not been cut with a tool. We will never know if this person tried to manipulate the lines and broke this; or if it was broken all along and he didn't notice until replacing other parts..... but the story does not add up.
The original design of this cabinet had a tube and fin condenser with a fan attached; similar to what would be found in a vending machine condensing unit. The replacement GE compressor did not have an adequate condenser configuration. These all run very hot. To prevent further problems, I replaced the non-finned condenser with a much more capable spiral condenser with fins and a larger fan.
Anyway; repairs have been done and I have documented these with the following two videos. It wasn't a simple case of repairing the break and replacing the filter-drier. GE actually installed a sintered bronze filter screen inside the housing of the intermediate pressure valve, buried deep within the cabinet. This was blocked and causing the system to be inoperative. I don't see why GE would place a filter vulnerable to plugging in a position like this, considering the amount of effort necessary to access it and work with the aluminum tubing.
Hope you enjoy seeing my repair videos!
Sincerely,
David
Part 1:
Code:
https://youtu.be/mFcplBQ6kcQ
Part 2:
Code:
https://youtu.be/AJSicfbTlGI
The first time I saw one of these was in a huge old house in Palmer woods in Detroit, where there are mansions. It was yellow. I thought what a nightmare to install, and service. It also didn't seen to have much capacity. The entire kitchen was that GE era in yellow. Push button cook top, and wall ovens.
The doctor I knew who had just bought it gutted everything. Since it was all in great shape and worked, the contractor sold it for him to a vintage collector out in the burbs. Everything new was Gaggenau from Germany. Deep fryer, convection steam oven, pizza oven, built in coffee center. Sub Zero fridge.
These were from an interesting era for sure. They seem to me; better suited for a smaller kitchen such as an apartment. In the remodeling job you mentioned; I'm glad the contractor moved the working vintage appliances on to another collector as opposed to scrapping them!
Nice job there!
Oh, and I'm Well Aware of the customer's infamous promise that "it needs a simple fix."
In my line of work, fixing Tv's, Stereos, etc., at the shop, I've heard that line a million times.
It's a subtle hint from the customer who dosn't want to spend a lot of money on their product. - A.K.A. a "cheapwad", trying to give them a break.
But sorry, just because your stereo doesn't play on one channel and requires extensive repairs and expensive parts, doesn't qualify for a discount.
I refused to do shoddy work, my reputation is important.
Awesome work as usual David. The ventilation holes on the top of the unit, did the GE come with them or did you drill them there ?
Thanks! I punched the ventilation holes with a conduit knockout punch. The newer GE wall fridges had similar holes, but a little smaller.
Nice job there!
Thanks! I totally concur about doing shoddy work. Never do it, as that will ruin your reputation very quickly. I have been extremely fortunate with the antique cooler and fridge repairs. Had one bad experience due to allowing the customer to pick up his item before I had thoroughly tested it.
In the case of the wall fridge, a previous seller tried to maximize their profits by claiming the fridge needed only minor work and demanding a high price. The buyer (my customer) was distraught because her first wall fridge had been lost in a restoration shop fire. She was desperate to find one to fill the missing piece in her kitchen; and was a vulnerable buyer for that reason. She's not a technician and only told me what the seller had said to her at the time of sale. She's been trying for years to get this worked on to no avail and had realized long ago this was not a simple problem.
In light of the hardship she has endured, I want to be very sure this will give good service once it goes home!
Sincerely,
David
