Hi everyone,
I'm a new member and could use some help please. I have a Mongomery Wards 20 cycle washer model LNC-6837 (purchased new in 1977). The motor is on it's last leg. The motor thermal protector shut it down and I could smell it burning. After it cooled off I took off the front panel so I could check out what was happening. I turned the washer on in a spin cycle and the motor buzzed loudly, started smoking and shut off again. I'm a pretty good mechanic and I'd like to replace the motor and keep the machine going if possible. The washer is in pretty good condition otherwise and I like it. Anyway, is there a replacement motor that will fit this machine. I took the motor out and it's 3/4 HP with the following numbers on it... 33-7323 and 5KH41LT11AS. Please help.
Robin
Robin
