Restor’ my Thor
adam-aussie-vac
Dec 14, 2017
1,044
Canberra ACT
Great news guys, it’s all freed up with a bit of time and turning and I think I might have to replace the wiring between the switch and the motor but the shift selector is now working. The transmission is turning and the switch probably needs a bit of a clean out.
View attachment 77458726848__5A4B0C86-EA88-4B5E-8851-B1BB96BDFD2A.MOV
Honestly I would never thought I would’ve gotten this far. Let alone physically have gotten the cabinet apart in two pieces, now all I need to do is replace the cables check if there’s oil in the transmission and then going from there as for somewhat reason there was a can of oil inside the machine like a small can about the size of the motor for the machine.
Great news I’ve replaced the original wiring between the wall plug the switch and the motor and it’s all working, I just need to make sure that the motor is going the right direction and it’s changing direction where it needs to if it does. (not sure how it works) but I’ll try to put a belt on it today.
