It also had a big dent in the front, but I was able to fix it, and the dent can no longer be noticed.
Also found two penny coins lodged in the hose from the tub to pump, which blocked the flow off. As I water tested the machine I wondered why there was not much water coming out. After spinning out a few tub fulls, I had the first 1957 Unimatic Sud-saver!! NOT!! I thought at first the pump might be defective, however as after removing the hoses, I found the blocked port. (and lots of water!)
I was told that if these machines work, one is not to do anything much else to them. So other than hose replacements,a new three wire cord, cleaning/polishing and putting the machine back together, that is about all I have done to it.
This machine runs very quiet, and sounds fine. So I must have lucked out with this baby.
OH!! I forgot.... POR 15 to the rescue!! The tub balance ring was rusting, so I cleaned it up, and gave it 3 liberal coats of POR 15. I plan to leave the ring black btw. (battle scars)
