rollermatic
how do i explain here! on a rollermatic the agitator shaft is in 2 peices. the main shaft connects at the bottom to the agitate arm and the top connects to a "stud" they call it, a nipple like peice about 3 inches long. the pulsator fits on this stud and is held down by the agitator nut.
on 2 of my rollermatics when i went to remove the agitator nut by holding the agitate shaft solid at the bottom instead of the nut coming off, the stud unscrewed from the main shaft.
hence the pulsator came off tearing out both water and oil bellows and leaving the stud attached to the bottom of the pulsator.
i know another member here has the same problem, i think it is "lebron", correct me if i am wrong.
i am glad to say i found a way to remove this stud from the nut and did it tonite!
here is a pictorial!
first, bottom of pulsator with stud still attached. you can see the remains of the bellows.
