Rollers for Frigidaire 1-18 Dryer
roller rejuvination
I've had fine luck by taking the rollers of their spindle, wiping everything clean, then re-assembling with a drop or two of 3-in-1 oil. It quiets them down and gives me another two years of use.
Roller Rejuvination
Actually there is a groove cut in the roller shaft that can be filled with a high quality grease which last a lot longer than just oiling them. The problem with 1-18 dryers is the rubber often separated from the plastic wheel, the best of the 1-18 dryers had only two rollers in the rear [ the last models they built ] before that roller problems were very common. The felt seals can probably be borrowed from other dryer brands.
thanks all
for the good counsel. Coldspot- let me know what you find. I'm not doing the work myself but the guy who is said both the rollers were "shot"....so apparently it has two.
1-18 Dryer rollers
It would have a minimum of 4 and most had 5, 2 in the front and 2 or 3 in the back.
Another good thing to know about rebuilding 1-18 dryers is a MT dryer blower fits a 1-18 perfectly, and FD used the same type of cheap attachment of the blower to the motor that MT did, so if the blower shows any sign of coming loose replace it now while you are in there.
John L.
