rancherman
have a RED4400Vq1 Roper dryer that's been bugging me all winter. High frequency vibration that really gets the sheetmetal cabinet humming.
I replaced the 2 rear rollers, front and rear 'bearing/seal' and the belt+tensioner, even though they didn't seem worn/loose/tight..
As bad a shape the rear seal was, I thought some of the vibration was due to chatter from running on a crusty surface.
Much like a steel shaft in a dry bushing can 'chatter'.
After putting it back together last night, nothing changed in the vibration dept. So, is this a motor/bearing/fan balance issue now?
side bar: dryer won't heat, or heat enough for the 'auto sense' part.. it quickly advances to 'off' like, in 10-15 minutes. Little to no drying or heating has taken place.
On "timed high heat" it works fine. There are no sensors in the drum, just the thermostat in the fan housing. Is this the culprit?
