kenmoreguy89
Hi All, so, the Servis finally had a timer, I just need to adapt the knob to the spline which is bigger....
So all I miss now it's the other 2 knobs, Mike is going to send me one...I hope I can find another one....
There is maybe a big problem though, since I had the timer working I could not wait to run some loads in it in these days, (I'd like to wait to have it "completed" before making a video to post here), well, tonight I was doing some laundry with it again, so transferred laundry in the spinner, ran the first spin after wash, all okay, so then I raised the lid to stop spinner and added water for soak filling and rinse spin, but got this bad surprise: trying to close the lid it didn't go down...I tried to push and lift the button but the lid just won't close, and spinner won't run of course, looks that the device got blocked, broken...who knows?
I removed the back panel and tried to see how that device looks like....I removed it's screws (screwed on the top) one of the which had a wire twisted on it, it should be a red/hot wire (black and yellow) and looks it gives current to the internal thing...it's really weird that device and honestly I have no idea of how it does work nor how to remove it in full, it does have cilinder inside that would go up and down and or back and forth...not sure...will take a pic tomorrow with daylight...someone knows what could be wrong with it? How to fix it?
Eventually how can I do to remove the top panel? I'm scared to do that though, because the boot in the spinner tub is very dry and could break very easily if I renmove it.... but them still available? That would be nice to replace it if posssible...
Thank you in advance!
Freddy
Freddy
