panthera
Always
sear the meat first, then raise it off the bottom of the pressure cooker, even if you're using lots of water.
Several folks have mentioned no lowering the pressure suddenly, that's right and give the meat the same time to rest as you would if it were a roast out of the oven: The juices redistribute over time and the temperature evens up.
Pressure cookers are wonderful if you're cooking far above sea-level, when I'm in the 'States, I cook at 6,000' plus. There, they do make a difference.
