After Ralph's thread on his vintage GE rotisserie toaster oven, and getting out my old Baby George rotisserie-only appliance, I set this weekend to rotisserie a 14 lb turkey in the semi-outdoor propane rotisserie grill out on the covered patio.
I've done this many times before, but after observing again how the Baby George gets by with just a rear heating element, I made a slight change. Previously I'd run one of the lower burners in addition to the rear panel rotisserie ceramic burner. Mainly because I was concerned that the oven temp (yes it has a good thermometer in the lid) wasn't getting above 100F.
However this caused other problems, such as the heat from the lower burner causing the dripipings into the drip pan to scorch and such. So I'd have to add water to the pan, and then that sort of defeated the whole notion as the water would take time to heat up and suck heat up in the process.
Anyway this time, while I did preheat the entire BBQ to over 450F, once I got the turkey in place (Mrs. Dash dry rub, light coating of avocado oil) I only used the rear rotisserie burner.
In the past by using the lower burner plus the rear burner, these turkeys would get done in a fairly short amouont of time, like 2-3 hours. However without that extra heat this one took a full five hours finally for the breast meat to come up to about 165. I was worried about that, but then I realized that I slow cook meats in the crock pot for more hours than that. And that when it comes to meat and poultry, slower times and lower temps can mean better results.
In the case of this turkey, it was true. When it was finally done, let it rest for about 30 minutes, and then carved some off to sample. Moist and tender, and fully cooked. I was impressed. And the drippings were not scorched and will make for a delicious gravy.
So in future I'll just have to allow more time for rotisserie cooking, since I do like the results.
This turkey may have been slightly different, though. Purchased frozen, it's a "White Honeysuckle", which of course if just one of those meaningless brand names. However the packaging it mentioned that the turkey had already been brined so to if more brining were done, to reduct the brine salt by half. Well, I generally don't brine so I just used it as is. When I sampled the final result I liked the slightly salty taste. Whether the brine made for a more tender bird I don't know.
