After 13 years of good use, my beloved Speed Queen seems to have developed an issue. The clothes seem too hot when removed after the dry cycle. Airflow, exhaust and seals are fine.
I have the service manual, but it lacks a schematic and timing cycle. I feel I know what is likely the problem but I want to check with the experts for opinions or perhaps field experience.
One test I did is to start the machine in the cool-down cycle and extended tumble cycle. The heating element comes on and cycles. This may or may not be normal as I don't have the schematic or timing chart.
The service manual refers to a "cycling thermostat" as something to test and a potential cause of this symptom. This would be the thermostat that advances the timer during automatic dry cycles. This appears to be the thermostat on the blower shroud (Correct?)
Service docs appear to go back to the timer repeatedly as to cause. This seems logical. What I may do is replace both the cycling thermostat and timer at the same time. Comments?
ON A RELATED (or unrelated note... I will ask another question.
As any dryer ages, failures can occur with any part. I am tempted to replace the heater box thermal fuse and limit thermostats (high limit) purely due to aging.
So my question to the techs is this: For aging clothes dryers, do you find there is a particular time in the life of a clothes dryer where replacement of the heater box thermal fuse and high-limit is prudent purely due to aging?
Thanks for any insights!
