Hi, does anyone know why the water fill in my Speed Queen top loader doesn't stop when it has reached the level for the wash size?
So far I have checked the:
pressure switch - diaphragm seems in working order
pressure hose - no apparent holes, builds up pressure if removed and tested in isolation
mixing valve - water does not continue to flow if power is switched off, strainer removed and cleaned
Does the mechanical timer play a role and could this prevent the water fill from stopping if faulty?
Any advice would be appreciated.
Thanks
Thanks
