Speed Queen salesman comments on water level - true?
water level
The manual operator's manual do mention the reset button. My ZWN432 HUEBSCH
is built to US specifications even if we do not (yet) have the same energy savings laws. I did increase the water of about an inch which brought me to the load size I used to do in my previous washer (GE Medallion RIP). I was told in this forum that I could increase the water level more but I deceded not to since I alredy turned the screw all the way 1 turn and the sevice manuals I found on-line says the pressure switch screw should not be turned more than a 1/4 turn. But then, those service manuals were from Amana and Amana built SQ which were filling up all the way. So although I'm glad I raised the water level... we can do all without. We can adapt to doing smaller and more loads (WHERE'S THE ECONOMY US GOV!) or do what I did... I raised the water level an inch+ and use the reset button for those occasionally large loads (4 to 5 a year in my case). Just start the machine, leave the lid open and attend... But again, you have to attend. And so should you should you have an "out of the ordinary load" in your machine.
Full fil of tub?
Do you get the full fill or higher fill of the tub like the 9s series? That's one of the features I like on mine. Know you can adjust the fill level but like the 9's higher fill from the factory.
