Use fast agitation for loads that are two-thirds to maximum capacity (unless they're delicates---sweaters, lingerie, etc. of course). Your Speed Queen has powerful agitation, so you may want to opt for slow agitation for, say, a load of only 6 or 7 dress shirts. You'll decrease the water level for a smaller load, so the clothes really get whipped around. Using slow agitation ensures the items in a smallish load won't get rough treatment, especially if you want to use a longer wash time (Heavy soil, which is around 12-15 minutes) to give the detergent more time to do its job.
On the other hand, if you're washing a smaller load of grimy white socks and towels, go ahead and select fast agitation.
Use a slow spin speed for loads of dress shirts/slacks (to help prevent wrinkling) or delicates. Choose a fast spin for everything else.
You won't need the extra rinse unless you have a family member who is very detergent-sensitive or if you use an extra large dose of detergent for a really tough load. I used the feature once or twice when I was a little heavy-handed with the Tide.
Regular Cycle: This is the one you'll use most often. In fact, I rarely use the Perm Press, Delicate, or Hand Wash cycles. Both the Delicate and Hand Wash cycles alternate brief periods of agitation with soak time.
Most of the time, I'd rather just set the Regular cycle to 'Light Soil' and get 6 full minutes of slow agitation. And with the 542, you can do that!
Perm Press Cycle: Is nearly identical to Regular, but with slightly shorter wash periods. If you choose fast agitation/fast spin on the fabric selector, the first spin will be slow, but the final spin (after the rinse) will be fast.
Delicate/Hand Wash: As mentioned above, these cycles alternate periods of of agitation and soaking. The spins will always be slow, even if you set the fabric selector for a fast spin.
Be sure to use enough water to keep the load "rolling over" at a moderate pace. It is better to err on the side of using a bit too much water rather than not enough.
You shouldn't experience many out-of-balance loads. Don't wash a single heavy item alone. Add a few other items to balance the load.
Enjoy your new Speed Queen! While I've been a front-load devotee since the mid-1980s (my "daily driver" is currently a 2010 Frigidaire) I also enjoy using (and get great results from) my AWN542. It's the last of the old-school top-loaders and should prove to be very reliable. [this post was last edited: 10/19/2014-16:14]
