SQ Dryer timer
jocks54
May 16, 2011
73
Danbury Connecticut
Hi Folks, I have a stacked 2007 SQ washer and gas dryer. The dryer timer is starting to "slip" like the teeth are worn when the dial is turned. It is a model #CTSA9AWN This unit has the control panel waist high. I am coming up with nothing for a replacement timer! I am guessing the 4 screws on the front panel can be removed and the knobs pried off to replace the timer? Where can I get a timer?? Thanks!
Thanks guys!
Do I carefully pry off the knobs? Any tricks?? After searching for over an hour Reliable Parts lists the CTSA9AWN unit, and has the part. No one else seems to. Don't know why! Wonder what it indicates? Will be sure to unplug both.
