squeaky compressor on Coldspot Startup
dalangdon
Jul 2, 2016
75
Seattle, WA
What with this, that, and the other thing (I've had a lot of drama going on recently) I've just finally gotten around to getting the Coldspot up and running.
It has been on for a few days now, and everything seems fine, cooling-wise, except for a rather grating squeal from the compressor when it starts up. Is this serious, or is there anything to do about it?
I have a refrigerator repair guy that owes me big time (I gave him a tank of R-12) so even if it is a big problem, it might be OK.
When that's done, I've got to get that green light on the door working...
In the U.S. you have to be licensed to buy R-12 and R-22. Automotive shops, appliance repairmen, and home air conditioner servicers are licensed. They have to use special scavanging equipment so that no R-12/22 leaks into the atmosphere. Most are using substitutes or are converting systems to newer refrigerants. I had my 1950 GE refrigerator recharged after Hurricane Rita (oddly, it looses all of its freon if it is turned off for a day or more, but loses none during normal on/off cycling), they used something other than R-12 and it is working fine. R-12 is so expensive now that it is cost prohibitive. I'm probably going to convert my '58 Buick to a newer gas as I'm almost out of my personal stash of R-12 (a 30 lb cylinder that I obtained years ago and have used very sparingly). When a refrigerator is discarded, many local areas have regulations that require that the freon be drained by a licensed repairman and the appliance is then tagged for pick up.
Incidentally, since R-12 became controlled, it has become one of the most smuggled items across the Mexican border.
Dan,
Sounds like your fridge isn't leaking.
I was referring to the previously common practice of continually adding freon to a leaking fridge. Unlike a car AC whick has lots of o-ring seals and slightly porus rubber hoses, a household refrigerator should never need freon, unless it has a leak.
Never buy a used fridge that has a tap-a-line on it (see link).
Ken D.
http://www.stridetool.com/tools/autospecialty/actoolaccess_02.html
