stacking different washer models is it possible?URGENT
whirlyfanatic
Sep 5, 2012
95
Trinidad and Tobago
Hey guys i need some advice can a dryer that is 29 3/4in. In depth be stacked on a 30 3/10 depth washer? Both of them are frigidaire affinity front loaders just the dryer is more basic... the height and width are the same only the depth differs.. if so how can it be done. Help please...
All you can do is take measurements and see if things will line up.  The dimensions sound very close, but you may have to do some rigging.  Since it's a relatively light weight dryer, if only two out of the four fastening points can be aligned with the stacking hardware, that may be enough, although I'm sure it's not recommended.
On top of that you can secure the dryer to the wall with a nylon strap like those used for securing scaffolding or bookshelves to the walls.
Check with Frigidaire. But you should be able to do it. Especially since they're both Affinity series. The stack kits look quite generic. They consist of a front bracket and two clips that attach to the back of the washer. You slide the dryer back and then to the left, onto the clips to secure. It's very stable
I have a GE electric dryer on top of an LG washer and another LG matched set both stacked w/out using the stacking kits. I used some rubber sheets to help stabilize and eliminate any vibrating from unbalanced loads. No issues.
