baltimore
Hi,
We have a 1959 GE Refrigerator that is not getting cool in the refrigerator compartment. The freezer works fine, but the fridge does not get below 60F in a 68F basement.
Background: The fridge was placed on its side for 30 minutes during transport, and the fridge was left upright for 2 weeks before we plugged it in.
During troubleshooting, I discovered this may has been serviced in the past. I see two issues:
1: In the Freezer Compartment, the metal refrigeration tubing seems to not be routed correctly (circled in blue in the photos). The module hidden on the back wall (wrapped in black foam and not visible in photos) has 2 lines coming out. One goes to the horizontal coil loop, and the other goes into the silver module (visible in the photos).
2. There is a single thin metal tubing line coming from the Refrigerator temperature selection knob. It runs along the top of the ceiling to the back left corner of the coil plate assembly, and then along the back of the coil plate to the right rear corner of the coil plate where the line terminates. It also appears the white/grey rubber grommets are not seated perfectly.
I am thinking about purchasing the online manual, but I wanted to see if anyone has any idea what happened during the previous service attempt. More importantly, I am wondering about what they may have left me with.
I am concerned the improperly routing tubing in the freezer compartment might be causing a problem if the R12 is in liquid form at that stage and requires a downward slope. I could fix this problem and still be faced with the original problem.
I am also concerned about the tubing from the Refrigerator temp switch. I'm not sure if that tubing is supposed to be in a loop with the Refrigerator R12 circuit (the TM should tell me this). This makes me think the line was possibly broken in the past allowing the coolant to leak out rendering the refrigerator inoperable. Maybe this is why they mucked with it in the first place.
Does anyone have any thoughts on how to proceed or do you see anything glaringly wrong? Is it possible to modify the system to be like a modern one where I blow cold air from the freezer into the fridge to maintain 40F in the Fridge? The 1959 system seems like a lot of complicated components to do what a hole, thermostat, and fan can do.
Thank you,
Jeff
Thank you,
Jeff
