mike
I have a Maytag A606 Serial# 624694US (Aug.'74). that stopped all Drive motor functions. Motor turns freely. I believe it could be Timer, Motor Switch or Motor. I need to know how to jump the motor for a diagnostic test.
With the tub full of water, i disconnected the 6 wires from the Timer. Activated the Timer (Timer motor works)and only got full voltage from the Yellow wire and some residual voltage on the other 5 leads. If the yellow is my Hot, what is the neutral and more importantly, which motor switch terminal is neutral?
The motor switch has a colored dot pattern from top to bottom: Leftside: black,red. Rightside: white, orange, brown, yellow.
Thanks and help my keep this warrior going!
