Some of you may remember this machine, anyways I just put it through the ropes. The motor reverses (clutch does its thing too) and both speeds work. The water container doesn't seem to leak, and the pump had no problem with about 3 gallons of water. But this machine still needs a total restore, as the bearing is a howler. The transmission is broken, and since there is no agitate belt, so I can't tell exactly what's wrong with it. Even though this machine is a '59 I believe it has the revised clutch (without the 800+ spin). DOES ANYONE HAVE A SET OF BELTS FOR THIS MACHINE?
<object width=425 height=344><param name=movie value=></param><param name=allowFullScreen value=true></param><param name=allowscriptaccess value=always></param><embed src= type=application/x-shockwave-flash allowscriptaccess=always allowfullscreen=true width=425 height=344></embed></object>
