The agitator's upward currents are a result of the horizontal currents, IMHO...you can feel the strong horizontal currents on the '82 with the Roto-Swirl, especially on 68 OPM! The "vertical" action (such as turnover) takes place with the curved ramps which help pull the clothes downward, but the base vanes are straight. On the GE, which, unlike the Roto-Swirl, has curved base vanes, it is stronger and faster due to the aggressive 100 OPM high speed. With the rapidly moving (330 on the Unimatic--Rollermatic; 360 on the 1-18) pulsator of the Frigidaire, you can feel the strongest horizontal currents.
I believe that there are two things needed for good turnover. You need a method of pulling the clothes down to the base (where the REAL action happens) of the agitator, and a way of bringing them back up again. The horizontal currents made by the agitator could be deflected upward off the sides of the tub, which results in the clothes coming back up to the top, especially on a Frigidaire, IMHO. That's why when a Frigidaire starts agitating, you can see the currents forming near the sides of the tub before the load is pulled down and starts rolling. With an indexing tub, the reason there isn't usually much turnover is because the push and pull currents aren't strong enough. The tub is constantly moving so theoretically there's nothing to "bounce off of"...add a weak agitator to the mix and there's no upward or downward movement. With the Westinghouse spiral ramp agitator, the currents it produces are strong enough to pull the clothes down and bring them back up, even with the indexing tub. Someone will definitely correct me on this, but I also believe that on the solid-tub Norges, there's not much turnover on a full load (however, on a light load, I learned that they will turn over quite well) because the stroke is too long and slow to produce strong currents to get a full load moving...instead it cleans by the dragging action; not one article will remain untouched. I know the design of the agitator (WIDE base) also has something to do with this. Same with the solid-tub SQs...they will roll the clothes when lightly loaded, but not on a "capacity" load. But the agitator moves fast, has large vanes, and the base isn't too terribly wide. So how could this be explained?
Very interesting topic...would like to hear more!
--Austin
