Well I’ve Completed Phase I of the Super Unimatic and washed about 10 loads in it this weekend. It worked perfectly except for some software tweaking. Its great fun, made for some very clean clothes. I used two cycles of Heating, one for undershirts/wear, the other for white towels. Both worked great, I measured the incoming water from the tap at 138F, during the Four Minutes of Magic Spray the water temp dropped to 120F and by the end of the 20 Minute wash/soak/heat cycle the temperature was above 130F. I wash a load of dark towels using hot water and no heat and the water temperature dropped down to 101F by the end of the 20 minute wash/soak cycle. So the heater definitely helped to keep the water temperature up.
Here is a link to the software I wrote to run the Super Unimatic. (You will get a security warning when you click on it because windows doesn’t recognize the program, but its safe to run.) It's going to be upgraded over time and I will add and adjust cycles, but it’s a good start. There are a few bugs left in it which I need to fix but you can get a good idea of how it works if you wish. just click on this link and select Run.
Here are pictures from the first wash load.
