The Hoover "Baby" 103--my oldest machine yet!
westytoploader
Sep 4, 2004
4,485
I've been after "early" Hoovers for quite some time, and when this 1910's Model 103 appeared I just had to go for it! They seem to be quite rare, as this was only the second one I had seen on eBay since 2001 if you can believe that! Even though this one is called the "Baby", don't let it fool you...it's bigger than you think! I was surprised to see that it the nozzle is the same width as my Convertible 31!
Surprisingly, the brushroll is in FANTASTIC shape as you can see and the tufts are still nice and soft! I was worried the most about this as I had seen a lot of older Hoovers on eBay with the bristles completely gone. I spent all afternoon cleaning it of the 70+ year old hair that had been wrapped around it and re-packed the bearings with white lithium grease. I almost thought with all that old, caked-on grease, the only solution would be to Varsol them, but after a thorough washing with soap & water everything came right off!
The motor initially ground horribly on startup. I oiled it with a small amount of electric motor oil (SAE-10 I believe), and the grinding is a little less. I was surprised at how smooth it runs after it sped up. I'm going to let it "sit" overnight. Any suggestions on how to adapt a belt to work in this one? I'm using a Model 63 belt in it now but it comes off and seems "loose". I wonder if a Junior belt will work?
However, as you can also see, the machine is in absolutely HORRIBLE cosmetic shape and will need a full restoration. Half of the right front wheel is missing, and it looks a lot like the base had been repainted a metallic color ages ago (I noticed some specks on the motor as well). Either that or the chrome has come off completely in some places. The (non-original) cloth bag seems to be in decent shape but has many repairs to it. It is very dirty, though, and it will probably look better after I handwash it. The wooden handle, motor, and brushroll holder will also need to be repainted. I removed the ugly grey rubber bumper on it (that was obviously non-original); but after I removed it I saw that one of the screws had broken off on the front beneath it. So it will need a new black bumper as well!
--Austin, who is anxiously awaiting to finally send in that VCCC registration form this August!
And here's the underside! The brushroll is in awesome shape, but the holder has seen better days and will need to be shined up again...
You can also see how loose the Model 63 belt is as well; not going to work.
Oh baby baby!
Austin,
Model 103 came out in 1920. In 1922 it cost $52.50 east of the Mississippi, and $60 to the west.
There are two sets of serial numbers:
615,000 to 711,700
3711741 to 3758388
Date of first production: June 4, 1920
Date of last production: December 3, 1925
Congrats on a great find!!
Older than yo mama
Well, hell, older than your great-grandma.
What a find! I'm not really a vac person but the Constellation, the orange Eureka and now this might be enough to convert me (like a convertible).
Machine's patina...
I believe that those machines shouldn't be buffed to a shine... They were still being sand-cast at that point, and had that sort-of matte finish to them. (So I've been told). But, shining them up is possible and does make them look fabulous!
I'll take pictures of my model 102 tomorrow, which I shined up before knowing it shouldn't have been.
I've got a set of service instructions for those motors, if you would like a copy, shoot me an email. Sleeve bearings on the top and on the bottom. If after lubricating it, and you still get the growl, the lower sleve bearing may be out of round. I have a model 102 in my posession that sounds like a jet engine taking off.. not quiet and purring like it should be (only when the belt is on the pulley, and putting stress on the lower bearing).
Try stretching out a Junior belt...or even a regular convertible belt. Put it around a vice and open it up for a few days, let it stretch out. That may work. I know for the regular sized machines, a stretched out/used Eureka belt works perfectly.
Congrats!
I have a sort of similar machine--it does have sort of a "Matte" finish from a sand cast mold.Love that unusual brush roll-brush "tufts" instead of the strips.The narrow brush roll would give low resistence to airflow.Its a good design.the machineI have is a later model the brushroll-has strips and beater bars.It looks like the "tufts" are replaceable-they look like they are held in with a pin or peg at the top.
i had a *special* the full size version of the *baby*. i also have a 700. its AMAZING how far Hoover went in just 6 years with the 700. i think the *baby* dates to when Hoover was the ONLY maker using a powered brushroll? my *special* used what looked like the same brushroll as the *baby* and ran whisper quiet, yet did a great job vacuuming. Austin, be careful with that switch and wiring!
Congratulations Austin, Glad that you were able to get it. I am amazed at the brushroll and the great condition it seems to be in. Can't wait for you to share pictures of it when you are done. Terry
Here's my 102...
I buffed it out, after realizing it shouldnt be (it should really have the same finish as the machine thats next to it)... but it's in great shape otherwise and runs perfectly. I cleaned the motor all out, put new carbon brushes in it (that was a task!), re-assembled it and voila! The switch, cord, and bag are all not original (obviously) but...nonetheless... it's my oldest machine, and really one of the prides of my collection.
wow that really shines!
Most of the sand cast cleaners should look like the one in the right of Fred's picture.
That one of Fred's is a real beauty though!
Fred, that is an absolutely GORGEOUS 102; she really gleams!!! You did a fantastic job shining her up! I'm wondering as well...how on earth did you do that? To me I think it would take a lot of polishing compound and an endless amount of buffing!
That is very beautiful, Fred, it really makes it pop out in the lineup!
I heard many times growing up that boys SHOULDN'T play with washers or other appliances and SHOULD grow up to marry girls but many of us proved them wrong! Have fun, that's what it's all about!
80 years old, quite a find!
Does anyone who have one of these happen to know how many watts it draws when in use? I have a hypothesis about vacuum motors...
