The Prize Winner of Defiance, Ohio
Unimatic1140
Administrator
Staff member
Apr 26, 2001
10,131
Minneapolis
Well the '55 Westinghouse Laundromat set is home and washing again after some transportation repairs (all mechanical and quite a few I might ad) were needed. The movie is called "The Prize Winner of Defiance, Ohio" which should probably be out next year.
For you Laundromat enjoyment...
Right Click on the video link and save target as (2.0mb)
http://68.89.57.239/VID/LAUNDROMAT/Laundromat.wmv
You can be SURE if it's Westinghouse!
Wow, great video! Slant-front Westys are the best; sure beats the Frigemores on the entertainment scale! A vintage slant-front Laundromat is my second most wanted FL machine, besides the 18 lb. Norge.
The action is a little slower than what I usually see, but still very splashy and sudsy! Guess I'm just used to a Bendix! :)
Aren't the surprise videos great? Keep 'em coming!
--Austin
Were they used in the movie???
Hi,
I was just wondering...were they used in the movie, or just as props. I think that seeing one of your vintage machines ACTUALLY being used in the movie would just be fantastic. And sending them possibly a sample of vintage detergent for added enjoyment would be neat as well.
Anyway...just thought I would ask....
Hey I have a question...when will the 58's Laundromat with Dash commercial be in the video section?
Chad
Hi Chad, no they were just props, but I was told they were seen quite a bit in the movie.
Actually I had not planned on posting the commercial from the Wizard DVD in the video library, at least not for some time yet.
Hi,
Thanks for the reply. I just think that it would be so interesting to actually see some of these "retro" movies using the actual props besides just sitting there for looks.
In most of these stlye movies, they use the cars from he period, and so what about the appliances...just my HO.
Anyway I did download the clip and your machines are absolutly stunning in every way. The rollover action of these beauties makes todays machines seem like their nothing more than glorified cement mixers.
Anyway I will be scoping out the movie when it's released....
Chad
HI GUYS
I HAVE THE SAME LAUNDROMAT AND DRYER AND WAS TOLD WHEN I GOT A NEW PUMP THAT THE MACHINE WAS A 1957, THE BOOKLET SAYS
L-3 FOR LAUNDROMAT, TURQUIOSE KNOBS AND ALL, ANY IDEAS AS TO
YEAR?
THANKS KIM
AND THE VIDEO IS GREAT, SAME SOUNDS AS MINE
L-3
Hi Kim, my machine is an L-8, which is a 1955 model, the L-9 was a 1956 model, L-5 was the 1949-1952 Model. I'm not sure when an L-3 is from exactly, but maybe someone out there has some service info with a more detailed date on you L-3.
L-8M not L-5M sorry
Hi Robert,
Thanks for the reply, my machine is an L-8M with matching
D-8M Electric Dryer, both have worked well for me, I currently using my 1957 Philco Bendix Duomatic, I'm also trying to talk my aunt out of her 1964 Philco top loader, its in her basement, doesn't work and she can't understand why I'd
want that old machine, I hope she weakens sooon.
Kim
Hi Kim, that means your Laundromat is a 1955 model. You should work on your Aunt to get that Philco, it is very rare to say the least. It would be a wonderful addition to any collection.
Prize Winner of Defiance, Ohio--the book!
Hi, all:
Out of curiosity, I got the book yesterday (same title as the movie) and started reading it last night. I'm only about 1/3 of the way through, but early on, the mother wins a Wizard washer/dryer pair, not Westinghouse. Top loading, too. The story about how she used to light the pilot is hilarious.
Well, given the mother's record, maybe she wins the Westy pair, too.
For those who haven't got the book: true story of the mother of 10 kids who manages to support the family by winning contests. Abusive/alcoholic husband/father, too. It's well written and thoroughly engaging; give it a read. Can't wait for the movie!
Bob
my L5
hey guys i have not only a question but first i want to say i love watching that video it lets me see what my laundromat is supposed to be doing. the L5 that i have here is giving me trouble and i cant figure out whats wrong. the day i got it i could tell the timer was shot but if i manually advanced it every thing would work. i filled it with water and a small load and off she went. she washed and drained and spun out like a good girl should. but then she sprung a big leak and the door boot needed to be replaced. so apart the machine came. got her all back together and found the speed changer was totally dry. i tried several types of oil till i found one heavy enough to keep the changer cool. so i thought all was fine. the machine will run a full cycle when dry but as soon as i put water in the drum and put the machine under a load the motor will kick off. i cant seem to get past this point. the belts have good tension and the timer is new nothing is binding. who out there is a laundromat wiz ??? i am out of ideas and would reall love some advice. thanks lots and lots chris
Hypoid Gear Oil
Hi Chris, make sure you using Hypoid Style Gear oil. I used it in my speed changer and it works great. The oil you are using is probably not made for Hypoid gears like the ones in the speed changer.
Next make sure neither one of the two belts are too tight and there could be a problem with the motor protector cutting out too soon.
Also.....
Chris, like I have said before, also check to see you havent' overtightened the motor bolt that holds the pump body. If you have too tight bolts on any of the 4 bolts then Westinghouse motors will quickly overheat and shut down. This was the problem with my L8, the prior owner threw it out right after a pump change because it would shut off right after the tub filled with water.
thanks
thanks for the advice !!! i will give these things a check and try come next weekend. will give me something to do while the bird is in the oven. once again thanks again so much.
well i tried
well i changed the oil and played with the belt tension. i have adjusted the belts every way i can think of with no luck. i checked the screws that hold the pump and the mounts for the motor. the best i can get it to do is run just about 30 seconds longer that it was doing. any more ideas?
motor stopping
does the motor start up again after cooling down? I acquired a later FL Westy (theone with a regular console on top) and it turns out that for some reason the wiring that went into the thermal cutoff in the motor had been reduced to only about 3-4 of the strands of wire. These would get hot and trigger the thermal cutoff switch.
motor stoping
the machine will not restart by itself. you have to pull the timer know out again for it to start again. the odd thing is that the motor will kick off but it is not hot the touch. i am so out of ideas its not funny
Sounds like you need a new timer, the motor protector is built into the timer in these slant front washers and it appears to be defective.
timer
i had replaced the timer with one for midwest. i still have the orig timer. i had wondered if maybe that was the problem or maybe i had a wire crossed. but im sure i didnt cross any wires. the orig timer worked fine except the tiny motor that advances it was shot. is there a way to change that tiny motor from the rebuilt timer to the orig timer. has anyone done that before. if so ill give that a shot.
