Thermostat wanted for vintage 1J367N GE electric stove
tommcnally
May 9, 2024
0
Peoria
I am searching for an oven thermostat for my model 1J367N GE electric stove. It currently has a non-operational Eaton 2610(or "D"),9576. Any leads, advice, compatible parts, etc. would be greatly appreciated.
WB21X5208
It looks like the GE part number is stamped on the back of your old thermostat - WB21X5208. Appears there are some on eBay but pricey. I believe an older part number may have been WB21X177.
You could also do some research to see what a compatible aftermarket one from Robertshaw or somewhere else would substitute to and do a search for one of those.
Make sure you keep that ring thats on the front face of the old one - its an adapter that is often needed on these old GE stoves to fasten a newer thermostat to the control panel.
GE oven thermostat for 1950s GE range
As you can tell the thermostat was replaced before the one you have was dated 1994 what’s wrong with that one sometimes it can be fixed.
Hopefully you can find another. There’s a bit of interchangeability on older GE stoves like that I could use one might be a good bet as well.
