The tub, et al
No, unfortunately the tub doesn't come out of the Thor. It's cosmetically gorgeous, but has its own set of issues to work through.
The machine agitates only slightly if you push hard on the plunger on the transmission that is tripped by the control cable, and even then, you can stop it with your hand easily, so there is internal transmission work to do, more than likely.
Still, it is a fabulous machine, and I'm so happy for Ross.
Mickey, the fill hose is present but not attached to the machine at the moment.
Austin, the White-Westinghouse is visiting its friends over at Nate and Melissa's, thanks to Ross' kindness--the Faux 1-18 is being dismantled for spare Westy parts, and its pretty control panel will be saved for posterity.
And I'll make a lamp out of that stupid straight-vane agitator (just kidding--but boy, I can't get enough of that ramped-agitator rollover!!)
--Nate
