drummerboy928
Today I finally decided to dive into the Westinghouse a little bit and started by taking off the back. There is a little bit of rust and dust, but overall i’m not overly concerned about the condition of things. However I did encounter a couple issues. I found the water valve was not properly connected and was why it wasn’t energizing when I tested it early in the winter. This was an easy fix but the belt on this machine was another story. It was laying in the bottom of the machine and extremely cracked. Would a belt from a newer WCI machine that says is the same part number work with this washer? I’ve included some picture of the machine for you guys to check out, as well as some of the belt so that anybody who knows these machines a little better could give their advice and words of wisdom on this. I appreciate all of you greatly!
