tom
Could anyone assist me in trouble-shooting a Maytag dryer, model DG409?
This has been a great machine. I don't recall ever having to replace anything except the belt. It seems as though at some point mid cycle I stopped getting heat. I've observed through the inspection door that the igniter does not glow (I assume that I should see it glowing with the machine running on a setting calling for heat). I've observed it in all the different cycles - auto dry, timed, etc. and on both Low and Regular temperature settings. Does it seem reasonable to begin by testing the igniter itself? If so, will a bad igniter simply appear as an open cicuit? Or will it be necessary to read the resistance of the circuit? (this appears to use a cylindrical igniter)
Thanks for any advice or information that you can share.
