Ok, ok...
I'm not sure I'd go quite that far... Debate can be healthy as long as it can be civil and not just be an arbitrary opinion used to beat someone over the head.
I'm not sure about the engineering standpoint but from a just looking at it from experience standpoint, and the countless hours spent watching different washer designs fill, wash and spin/drain for both work and fun, I've seen some really nasty loads where there is just all sorts of unholy nastiness floating suspended in the suds at the top and the Maytag spins and drains so I see that stuff swirl away thru the spin basket holes and be drained away vs. watching the water drain down first and seeing that sudsy nightmare drop down with the water level, exiting the tub THRU THE CLOTHES. What sense does it make to work to wash the dirt, etc, out of the fabric to just put it back in? What is the use of a fancier agitator system when it is capable of redepositing soil? Kinda like designing a fancier doorknob while it still can't keep the door latched.
At least the spin/drain machines have a better track record of keeping themselves cleaner. The swirl away action rinses the tub out even to the tub cover. The neutral drain machines leave all sorts of smelly, disgusting residue inside the outer tub up top near and even ON the tub cover. You, I'm sure, have had to do service calls where the customer complains of a foul, moldy smell and simply had to take a putty knife to scrape what I call the 'Kenmore Krud' off. If that's the mark of a 'sophisticated' design, I'll stay with my 'primative' Maytag (and similar spin/drain) system.
I own both systems and have nice things to say about both but the neutral drain systems, as a rule, tend to be more complicated mechanically . More to wear, break and be fixed (sometimes expensively).
Primitive. Sometimes it's just more efficient to use a club. Clean, simple and gets the job done without any repairs. To the club, anyway.... Lol!
RCD
