Laundry Room
Hi Keith, yes it works really well, Mathew completely overhauled the spinner, new spin bearings and seals, rubber mounts checked and a thorough overhaul before it was sited in place - it sits on a raised plinth in a rubberised base tray, the cabinet front lifts off, if you need to remove it you simply use a jack to lower it and it slides out, I added a flexipipe for the tub empty the spinner is gravity drain, all pipes exit underneath to drain, no sudz return!!
If anything it balances better than freestanding, as all Servis Supertwins are mounted on their own baseframe it has had no issues with OOB, it seems to correct itself from any excess vibrations!!
